Konica c227 with the error (99-01) ONLY happening from tray 1
  • HarryBurgess
    • Oct 2019
    • 25
    Hi,
    I've got a Konica c227 that after a few pages jams.
    The issue only occurs from tray 1. Tray 2 and the Manual feed are both working fine.
    Before I start chopping and changing parts, I was just wondering if there's an easier fix.
    Thanks.
  • tsbservice
    Field tech
    • 7929
    Re: Konica c227 with the error (99-01) ONLY happening from tray 1
    Originally posted by HarryBurgess
    Hi,
    Thanks.
    What's the counter?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4554
      99-01 is a paper size error. Are you sure the correct size for tray 1 is locked in? If you look at jam history does the size match the size that's in tray 1?
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 298
        Hi,
        Thanks.
        Sincro clutch.
        Field technician since 1994
        • HarryBurgess
          • Oct 2019
          • 25
          What's the counter?
          Counter is at 60k
          • HarryBurgess
            • Oct 2019
            • 25
            Yes, taken a look at the jam history and the paper size matches up on each error.
            • splblazer91
              • Jul 2014
              • 204
              Hi,
              Thanks.
              Had one like this last year. Ended up being Tray 1 lift motor.
