Bizhub C244e prompting fault codes C-2558, C-2556, C-2554 & C-2552
  • Rookie
    • Sep 2023
    • 24
    [Error Code] Bizhub C244e prompting fault codes C-2558, C-2556, C-2554 & C-2552
    Hello guys, I am having these fault codes C-255(8,6,4,2). I checked and confirm physically all developers and drums are ok, I cleared the error code by pressing the Reset botton and switching it on. But after 10-15 print outs it gives the error code again depending on what colors I am printing. If printing black it gives C-2558, yellow C-2556, magenta C-2554 and cyan C-2552.
    Should I replace all drums and developers with the PRCB?...
  • stronghold
    • Apr 2023
    • 47
    Re: Bizhub C244e prompting fault codes C-2558, C-2556, C-2554 & C-2552
    Hello,
    I think we shouldn't rush. I am inclined to believe that the issue is more with the software.
    I had a "somewhat" similar problem. It wouldn't save the installation date of the developing unit. Then the image units started failing. Sometimes it wouldn't recognize the magenta, sometimes the black.
    After that, it even started to give an HDD error.
    I struggled with this MFP for a long time. But one day, upon turning it on, it gave me a new error indicating a problem with the non-volatile memory. At that point, I was truly at a loss.
    However, as it turned out later, the culprit was the BIOS battery, which powers the board with TMP keys and data about the installed units.
    I recommend starting with this.
    Look this post
    Good Luck )))
    • tsbservice
      Field tech
      • 8020
      That happens when you play with dev units from donor machine. You can't swap them just like that.
        • 14812
        You have to take the TCR sensors from the original dev units and put them on the donor units.
        • tsbservice
          Field tech
          • 8020
          You perfectly know it's not so easy. You also MUST pray when replacing all 4 Dev units with second hand. Because at this point machine is probably beyond any reasonable repairs.
            • 14812
            I only use donor units in an emergency.
            • tsbservice
              Field tech
              • 8020
              The key is to prevent that
              • copyman
                Owner / Technician
                • Sep 2005
                • 4721
                Hi, I've swapped DV units from one machine to another many times with no issues. Actually only DV unit I've bought new is the less expensive black. With colors I replace any lost developer and reuse. Years ago I would convert black DV units into color but once I found out you could swap them with no issues that's all I do now. Since I've been upgrading the "4" series I have a lot of donor machines to steal DV units from.
                • REGSIS
                  • May 2016
                  • 435
                  I can confirm this. I did this only couple of times, but it works. It is recommended to stabilaze the image and run gradation adjustment. There should be no issues because TCR sensor is reading the T/C proportion; it's not written into the machine.
                  @original poster
                  Vacuum out the toner hoppers (disassemble first).
                  Replace compatible toners with OEM.
                  Run halftone patters of each color to extract old toner from dev units and lower TCR ratios.
                  P.S. Only with compatible toners you can get high TCR.
