LED DISPLAY "9A" in Fiery E100-02 For KM Bizhub Press C6000
  • reonjaysai
    • Feb 2024
    • 1
    Hi, anyone can help me how to solve this problem to turn back to "00" ? cannot connect to network. Thanks a lot
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: LED DISPLAY "9A" in Fiery E100-02 For KM Bizhub Press C6000
    have you removed the fiery cover and made sure everything is snug?
    i dont recall if it was an A9 error but the CPU heat sink had 1 broken leg so the cpu would overheat and shut down or reboot.
    id check it physically then plug a monitor into it and a keyboard.
    during the initial boot you can get into the BIOS like a regular computer and check out the hardware status tab. look for temps out of range.
    outside of that, try replacing the HDD and run system software on it.
    this is a IC-413 correct?
