Konica Minolta Bizhub C227 small black streaks on prints and copies
  • Marquee
    • Sep 2018
    • 6
    [Misc] Konica Minolta Bizhub C227 small black streaks on prints and copies
    Hello,
    the problem concerns a Konica Minolta Bizhub C227. An enduser has narrow black stripes and streaks on the prints. Glass plate is clean. No toner contamination. Meter count: 20K black 35 K color.
    I think it is a problem with the (black) drum or transferbelt? What do you think?
  • femaster
    • May 2011
    • 1513
    Re: Konica Minolta Bizhub C227 small black streaks on prints and copies
    Originally posted by Marquee
    Hello,
    Many thanks in advance for your advice. [ATTACH=CONFIG]61689[/ATTACH]
    The color versions of the 7-series machines, especially the earlier units, were notorious for prematurely wearing out the transfer belts which resulted in streaks. There was a redesigned belt, updated firmware, and an engine switch setting that was supposed to resolve the issue. That being said, the first signs of this issue were usually dual streaks on the pages from the calibration patches not being cleaned off the belt. That is only a single streak, but but does look like it could be a cleaning issue with the belt, so my first thought would be to take a look at the transfer belt before anything else.
    • Marquee
      • Sep 2018
      • 6
      I'll first check the cleaning blade.
      But could you please tell me which engine switch setting you mean? Thanks again in advance.
      • zawmyo201210
        • Oct 2022
        • 51
        You can check blak developer unit pounder. If the magnetic powder is low, this symptom also appears.
        • femaster
          • May 2011
          • 1513
          The Engine switches will only work if the firmware is updated to G00-N5 or newer.
          They have also made available just the cleaning unit as a replacement assembly under part number A797R74100.
          The following is pulled from the technical bulletin (#10997):
          • allan
            RTFM!!
            • 5462
            Are those lines in the feed or cross feed direction?
            Whatever
            • Marquee
              • Sep 2018
              • 6
              (Due to time difference I wasn't able to reply sooner) The lines are in the feed direction. The attached image is an A3 print.
              • stronghold
                • Apr 2023
                • 47
                Issue with the cleaning blade on the image transfer belt.
                If the problem were in the drum unit, the pattern would repeat with consistent frequency.
