Bizhub c6500e doesent accept fs-607 finisher
  • Bogdan1306
    • Feb 2024
    • 4
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: Bizhub c6500e doesent accept fs-607 finisher
    just to clarify, a Bizhub Pro C6500 right?
    there is no e at the end correct?
    if so yes an FS-607 is compatible with the Bizhub Pro C6500.
    • Bogdan1306
      • Feb 2024
      • 4
      Nope Bizhub pro c6500E
      • Synthohol
        • 5905
        i just realized im only considering US market, i forgot other countries have extra numbers or letters sometimes.
        if the finisher is popping icp fuses maybe something shorted?
        when i was brave, id unplug all connectors from the FCB and plug them in one at a time till i found a sparker and trace the short.
        you can also use an ohm meter on the connectors and make sure the pinouts for ground are the only ones showing resistance with the frame.
        if you find one that was supposed to be 24+ and the meter beeps then remove one connector at a time until there is no resistance and inspect that circuit.
        • Bogdan1306
          • Feb 2024
          • 4
          So i inspected all the Signal cables, And all the voltage cables, all are Ok, the finisher recive power But the printer doesent see the finisher. What i dont do right?
          • Synthohol
            • 5905
            hopefully this is a good hunch, that finisher has a stacker in it right?
            unplug the stacker wires from the frame connector and see if the error goes away.
            i cannot find the fs607 install instructions as i lost my access a year+ ago.
            • Bogdan1306
              • Feb 2024
              • 4
              What stacker? Is only the booklet finisher with post inserter.
              • Synthohol
                • 5905
                the stacker is the booklet part.
                when you slide out the stacker, follow the arm in the back of it to find the connectors.
                finisher may work independently so i was just trying to isolate the problem from the normal finisher part vs the stacker and its circuitry.
