Konica Minolta C7000 replacing transfer cleaning unit SETTING TONER
  • Honpress
    self service
    • Oct 2022
    • 62
    Hello!
    I'm going to replace the transfer cleaning unit (with that a new blade as well). On the internet I see they are using a special toner: Setting toner Nr. 2 A50UPP0100.
    But the problem is that I don't have this. It's really hard to find it or when I do find it, they do not ship it to the Netherlands! I recall that using regular yellow toner is not preferred because it contains a small amount of developer which could damage the transfer belt. So what else can I use as replacement?
  • wjurls
    • Feb 2017
    • 501
    Re: Konica Minolta C7000 replacing transfer cleaning unit SETTING TONER
    You can use regular setting powder or yellow toner from another machine that doesn't have carrier mixed in.
    If you are replacing the belt cleaning unit, there will most likely already be enough waste toner on the belt when you remove the old unit to lube the new blade anyway.
    • Honpress
      self service
      • Oct 2022
      • 62
      Hello wjurls, Thank you for your response! But doesn't toner from another machine also contains another carrier that will damage the belt?
      I'm also replacing the transfer belt itself, so I will not have waste toner.. Maybe a super dumb idea, but what about 'lubricating' the blade with calc powder?
      Don't know why it is so hard to find this stuff
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5892
        from the dawn of the c6500 if i didnt have my setting powder bag id just use yellow toner from the machine im working on.
        i dont recall any consequences ever.
        fwiw the part# for konica setting powder is
        000V-19-0
        000V190 Setting Powder 000V10020
        it will never run out. 1 bag for life.
        • Honpress
          self service
          • Oct 2022
          • 62
          000V-19-0
          Hi Synthohol, thanks for your response. I was able to order a small bottle from Germany of that setting toner, so have to wait till I receive it. Better safe than sorry haha
          • Synthohol
            • Mar 2016
            • 5892
            i usually "blot" the whole side of the belt, turn it backwards a bit while playing with cleaning blade tension to allow powder on both sides of blade which helps prevent flip.
            • Afanasy
              • Aug 2023
              • 35
              Hello. The fact is that on the c7000 there is no developer in the toner, so you can use any toner from your machine
