Scan via SFTP
  • jwai
    • May 2018
    • 509
    Scan via SFTP
    Hello,
    Which model(s) support scan file with SFTP?
    Best regards,
    • 37533
    Re: Scan via SFTP
    SFTP is mostly a function of the server not the client. If it is not available on the server, the client cannot use it. In house IT people for major companies do not allow any type of FTP on the networks they support and will black ball any vendor any vendor who attempts to implement it. Most consider it as still less secure than SMB v1.
    • Hart
      • Feb 2024
      • 421
      Re: Scan via SFTP
      SFTP =! FTPS
      SFTP is probably one of the most secure way to transfer files.
      • allan
        RTFM!!
        • 5462
        Re: Scan via SFTP
        Originally posted by Hart
        SFTP =! FTPS
        Have you set this up on a bizhub before?
        Whatever
        • Hart
          • Feb 2024
          • 421
          Re: Scan via SFTP
          Nope I'm not trained on Konica.
          Looks like only Brother offers to scan to SFTP with public key auth.
            • 37533
            Re: Scan via SFTP
            SFTP =! FTPS
            Actually not. They are 2 different protocols and have different advantages and disadvantages.
            SFTP uses Secure Shell (SSH). FTPS uses SSL/TLS.
            SFTP vs FTPS: Understanding the Differences
            • rrrohan
              • Sep 2011
              • 1977
              Re: Scan via SFTP
              isnt SMB more secure than FTP? why not just use that instead
              • allan
                RTFM!!
                • 5462
                Re: Scan via SFTP
                SMB is more secure FTP IMHO is simply more robust.
                Whatever
                • Hart
                  • Feb 2024
                  • 421
                  Re: Scan via SFTP
                  "SFTP is mostly a function of the server not the client. If it is not available on the server, the client cannot use it. In house IT people for major companies do not allow any type of FTP on the networks they support and will black ball any vendor any vendor who attempts to implement it. Most consider it as still less secure than SMB v1."
                  • avecosat
                    • Jun 2012
                    • 305
                    Re: Scan via SFTP
                    I talked to KM yesterday and only the BH 5020i (Brother) can do SFTP. I have a Lexmark XC9235 (KM C258) in my storage and it does allow SFTP.
                    • Synthohol
                      Certified Konica Expert
                      • 5849
                      Re: Scan via SFTP
                      just putting this out there, scanning to a USB stick is probably as secure as you can get. no?
                        • 37533
                        Re: Scan via SFTP
                        As long as the USB, or SD card, is not infected with malware that can infect your MFP and/or call home and send your files as soon as you put it in your computer.
                        • Synthohol
                          • 5849
                          Re: Scan via SFTP
                          since security is the theme, i hope HDD data overwrite is on the copier so the file images cannot be extracted
