Bizhub 450i Blank prints when original runs through ADF
  • 72Renahs
    • Oct 2023
    • 3
    I have a KM Bizhub that will print off the glass but when the original runs through the ADF the print is blank. Rear of page prints when duplexing. The scanner board and ADF board has been changed. P8 firmware. What would cause this?
  • tsbservice
    Field tech
    • 8064
    Re: Bizhub 450i Blank prints when original runs through ADF
    Does the scanner LED lights where this happen?
    • 72Renahs
      • Oct 2023
      • 3
      [QUOTE=tsbservice;2584098]Does the scanner LED lights where this happen?
      Yes the LED lights up.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4785
        Only thing left is the CIS (contact image sensor)
        • mascan42
          • Oct 2008
          • 486
          Are there any error codes in the history? Rather than a fault in the CIS itself (which should cause the problem from the flatbed as well) I'd think it might be out of position.
          • 72Renahs
            • Oct 2023
            • 3
            These codes were in the history.
            D391
            9401
            D301
            Upon running diagnostic and recovery tool I got a SSD NG. Storage board was replaced
