C458 rainbow effect scanning
  • cube10025@gmail.com
    • Aug 2022
    • 55
    I have a C458 machine, print fine but all the scans has a rainbow on them, or whatever you call it, see pic.
    I have cleaned the glass, run a non-image, gets several na1 but one ok but did not do anything.
  • aberock
    • May 2022
    • 104
    Re: C458 rainbow effect scanning
    try replace ccd.
    • Albonline
      • Sep 2008
      • 1131
      a to d converter on ccd board, small chance it could be ram (scans are stored from the top of memory down). did you do anything to it recently ? the image looks digital but I can't tell for sure from the image posted.
      • Gift
        • Mar 2011
        • 2444
        looks digital indeed, if re-seating the CCD cable won't help I'd probably swap the CCD, perhaps you can borrow one from a donator.
          • 22927
          I agree with this one. Konica Minolta CCDs that do very long scan runs are well known for failing on the 654e series, and 808 series. Usually they store errors that auto-reset, but come back more & more frequently. Try re-seating the cable first, then the CCD.
            • Aug 2022
            • 55
