bizhub 227 prints lines
  • kranyan
    • Oct 2020
    • 10
    Hello,
    bizhub 227 some times not always prints lines on a paper ,a picture example is attatched to this poste.
    what Could be the problem,Thank You
  • Ziggy
    • Feb 2018
    • 774
    Re: bizhub 227 prints lines
    Originally posted by kranyan
    Hello,
    Which orientation is paper running? What is life of drum, developer, transfer belt .
    • allan
      RTFM!!
      • 5462
      There is a high voltage leakage between the drum unit and the devtank.
      Sure you can feel the developer on the paper?
      Any scratches on the drum ends?
      Did the dev colors collapse or the seals worn out?
      Whatever
      • kranyan
        • Oct 2020
        • 10
        hello,
        yes there is scratches on the drum ends,as i said it only prints those lines from time to time,some times it works fine .
        Thank you for your reply
        • tsbservice
          Field tech
          • 8020
          hello,
          New black drum and developer unit and you should be doing well they're very cheap for their life.
