problem with pdf/a konica minolta c 258
  • enricocopyline
    • Jun 2018
    • 122
    Good morning I have a problem installing a PDF/A license on a Konica Minolta C258
    when I go to apply the license from service mode... stop 9...
    I enter the codes and it says UNABLE TO CONFIRM SETTINGS
    I updated the firmware
    do you have any idea what the problem could be?
  • Synthohol
    Certified Konica Expert
    • 5831
    Re: problem with pdf/a konica minolta c 258
    what are you trying to enter?
    the token code?
    did you go to LMS and use the token code to get the license code?
    what is you're procedure?
    • enricocopyline
      • Jun 2018
      • 122
      the token code?
      it is a license that I transferred from one Konica to another
      I generated the license code in LMS by deactivating it
      from the other and generating the new license code and function code
      • kingarthur
        • 1363
        Have you finished removing it completely from the old device, once you've removed it, you then have to print off the deactivation complete code, then enter that into the LMS. Are you using the original token code to generate a new license/function code.
        • enricocopyline
          • Jun 2018
          • 122
          yes yes I did everything right in LMS
          it doesn't even give me the repair button in the services,
          do you know why?
          • enricocopyline
            • Jun 2018
            • 122
            do you know why?
            I probably have a problem with the serial number because it tells me by entering the token code:
            serial number error
            I checked but the serial number matches P
            robably some card has been replaced?
            like emmc
            How do I fix the situation?
            • enricocopyline
              • Jun 2018
              • 122
              is it possible to remove the code from lms without putting it in the machine?
