es2000 spectrometer on fiery command workstation 5.3.1
  • zubinn
    • Sep 2017
    • 49
    hi, i use fiery command workstation 5.3.1 with a konica c7000
    under calibration i see the choice for ES1000 / Xrite DPT etc etc
    How do install or enable ES2000 ?
  • romario
    • Jun 2020
    • 192
    Re: es2000 spectrometer on fiery command workstation 5.3.1
    You have to look for the driver for e2000, when I go to the office I can give it to you
    thanks
    • Saturn
      • Nov 2023
      • 171
      You need to have Fiery Command WorkStation 5.7 or later to connect the ES-2000.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • zubinn
        • Sep 2017
        • 49
        inchecked the fiery download site they currently only offer Cws 6x
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5853
          If you web In to the fiery you can download CWS from there.
          • Saturn
            • Nov 2023
            • 171
            So why don't you use CWS 6?
            • zubinn
              • Sep 2017
              • 49
              is that the best solution ? it may disrupt production if it does not install properly, so i would need to install it on a separate computer to try it out, and if it works great, but if it doesnt at least i have my other computer intact
              • Saturn
                • Nov 2023
                • 171
                You can install the CWS on different computers, e.g. one computer with CWS 5.3.1 and one with CWS 6.x.
                So you can use the computer with CWS 6.x to calibrate the machine using the ES2000 and the one with CWS 5.3.1 to manage the print jobs.
                • zubinn
                  • Sep 2017
                  • 49
                  great idea i will seriously give that a shot.
                  • Synthohol
                    • Mar 2016
                    • 5853
                    i have both v5 and v6 on my laptop, just have to specify when installing 6 you want to leave 5 alone and not upgrade it to 6 but install a separate install.
