Black text and black background duplicate
  • Promise
    • Jan 2024
    • 19
    IMG_0475.jpgBlack duplicate in Bizhub c451 I have change cleaning blade, black polygon motor, complete gear box, printer board, main board, high voltage board up and down, transfer belt but is not working
  • mascan42
    • Oct 2008
    • 485
    Re: Black text and black background duplicate
    Sample is too small, I can't tell what the problem is.
    • Promise
      • Jan 2024
      • 19
      • Synthohol
        Certified Konica Expert
        • 5846
        hard to tell from a postage stamp.
        please post a full size or at least a 50% image.
        • mascan42
          • Oct 2008
          • 485
          I think that might be a board issue. All attachments are suddenly showing up tiny.
          • Promise
            • Jan 2024
            • 19
            Here is the image
            • Promise
              • Jan 2024
              • 19
              I have change the printer board, laser and laser board but still the same
              • mascan42
                • Oct 2008
                • 485
                The message board I mean. The pictures you post show up too small to see any detail.
                • Synthohol
                  • 5846
                  Originally posted by Promise
                  Here is the image
                  another postage stamp
                  • Gabriel
                    • Jun 2006
                    • 140
                    These types of ghost prints are usually created in the imaging unit and/or the fusing unit.
                    It doesn't seem like it but it could be incompatibility problems
                    If you haven't done it try this
                    1-Do not print it from a browser like Google Chrome, Firefox or Microsoft Edge, instead use a PDF program like SumatraPDF and print from it.
                    2-If you are printing from a recent version of Mac or Windows 11, try printing from a PC with Windows 7 and make sure it has the correct drivers
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4718
                      Agree with Gab, repeat image / ghosting is caused by drum or fuser.
                      • JasonSBE
                        • Apr 2014
                        • 186
                        This is happening with plain paper, or are you using card stock? If you're using card stock, have you set the paper type correctly?
                        If it's happening on plain paper, send a print job, and open the door to try and catch the paper after it's gone through the image transfer, but before it hits the fuser. If the paper has the issue before the fuser, it's probably an issue with the drum or the erasure lamp. If it happens after it hits the fuser, it's probably the fuser.
