Konica BizHub C284e color issue
  • PeteOJ
    • Feb 2024
    • 9
    hello
    when my user print a page we notice that the middle of the page the color is not ok
    in some it should be green and its not and other page i see it was suppose to be grey and it's not
    what can we do and what could be the problem ?
  • tsbservice
    Field tech
    • 8043
    Re: Konica BizHub C284e color issue
    Samples?
    • PeteOJ
      • Feb 2024
      • 9
      Samples?
      well i did a color sample it seems to be ok but when they print a word document or excel document the middle have the color incorrect
      • allan
        RTFM!!
        • 5462
        You need to print out the gradation test prints from service mode called half-tones. Are you a technician?
        Whatever
        • Synthohol
          Certified Konica Expert
          • 5879
          if its letter\A4 print it landscape see if the issue rotates.
          if you print the 4 gradient patterns in test mode that should be all you need to see if its the image or machine.
          • PeteOJ
            • Feb 2024
            • 9
            Hello
            im not a printer tech but i can find my way
            how to print a gradient sample ?
            • Synthohol
              • 5879
              service mode, test mode, gradient pattern y,m,c,k one at a time.
              11x17/A3 for the best results to also see if its a belt issue.
              • PeteOJ
                • Feb 2024
                • 9
                Hello
                i have 11 x 14 paper is it going to work also ?
                really it's the middle of the paper that have the incorrect issue
                • PeteOJ
                  • Feb 2024
                  • 9
                  Hello
                  also how to enter service mode on this Model ?
                  also what will be the password ?
                  • Synthohol
                    • 5879
                    PM sent.
