Bizhub C759 jam 66-05
  • Radiscar
    • Jun 2019
    • 74
    I have a Bizhub C759 that is jamming 66-05 in the adf. I have managed to get it to not jam for normal paper but the customer is scanning that horrendously thin yellow carbonless copy paper that they use in the field.
    It has been in this dusty location for a good number of years and quite worn, pieces that don't usually get replaced have.
    I have
    tightened springs on sensor arms
    replaced rollers and clutches
    lubricated the white rollers to roll better
    made sure all the sensors are clean along with the paper path and rollers
    replaced the front lock latch (cracked)
    replaced the sheet A3CK300102 as it was worn through
    Any suggestions what else I can look at?
  • Synthohol
    Certified Konica Expert
    • 5735
    Re: Bizhub C759 jam 66-05
    there is a chemical in some carbonless papers that eats rollers.
    konica likely has a certified brands of paper that was tested ok.
    have you tried setting it to thin originals?
    • Radiscar
      • Jun 2019
      • 74
      Thank you, I will look into the paper brand next time I am onsite.
      ...I will also try the thin original setting -I was unaware that was a thing as I have limited experience with konica
      • tsbservice
        Field tech
        • 7911
        Another model but should work:
        • Synthohol
          • 5735
          from my experience most of the multi part NCR papers were printed on printing press and well lets face it, a multipart form is so you DONT have to make copies of it!!
          next time get 4 part
          but i hope the thin original setting helps.
          • Mildred
            Old Technician
            • Aug 2021
            • 4
            Hello Radiscar,
            I know you mentioned that you cleaned all sensors, normally a J66-05 is caused by the pre scan PS6 sensor being soiled, also make sure the "black pad" the sensor looks at is clean. Ie pull back the guide and clean. As per sample picture "1" for Black Pad, and PS6 sensor "2".
            Just a thought. hope it helps.
            regards Rob
            • Radiscar
              • Jun 2019
              • 74
              Hello Radiscar,
              regards Rob
              I would just like to thank you all; the issue was quickly solved -it was indeed the black pad and I also showed the customer the "thin original" setting. The NCR paper they are scanning is unfortunately another companies paperwork so sadly there's no input to get it changed.
              Again, Thank you.
