Error code C-4101
  • marlon29
    • May 2011
    • 51
    Error code C-4101
    Good day,
    We have encountered this error code C-4101 on our AP C4070.
    Already tested to swap the PH unit with other color ( they are all the same), but the error still the same.
    Also tested PRCB, error still the same.
    Swapped DCPS1 and 2, still same error.
    Any thoughts on this?
    regards,
    Marlon
  • Ziggy
    • Feb 2018
    • 813
    Re: Error code C-4101
    Try updating firmware and if that doesn't help you could have wiring problem, you can try cutting wire ties.
    • marlon29
      • May 2011
      • 51
      Hi Markks,
      Done firmware update, but to no avail, we still get the same error code
      regards,
      Marlon29
