C450i to c250i
  • Max
    • Oct 2011
    • 552
    C450i to c250i
    Hi. Has any one tried a c450i drum in a c250i. Obviously the chip is different. As the c450i drum is cheaper for some reason, perhaps some one tried already?
  • CP-1015
    • Nov 2020
    • 311
    Re: C450i to c250i
    Not tried. But chips are different.
    • CopierNerd
      • Feb 2015
      • 207
      I have tried. Chip is not an issue. It can be replaced. The problem is drum unit frame and some other parts. They are different. You have to transfer everything to the old drum unit. Its not that simple.Just unbox drum unit and Install. Naaah....!
      • occus
        • 332
        CopierNerd
        Today i have installed a rebuilded DR-316 color Drum from a c250i in a C450i. I changed the chip for a c450i and I didn't find any problem. What was the problem for you? tested about 60color prints.
        • Max
          • Oct 2011
          • 552
          The drum drive shaft couplings are a little different. I was getting a white band as the drum was engaging a bit late.
