C6500 5mm Jump
  • Calculated Design
    • Aug 2025
    C6500 5mm Jump
    C6500 IC303 1.7 million
    Simplex and duplex jump 5mm
    Replaced the following
    Both ADU/PFU centering sensors 2 times
    Replaced IPB board with rev 28
    Latest firmware reflashed multiple times
    Followed trouble shooting tech guide ver 2.0
    I have been fighting this problem for months.
    Jump occurs on all weights and sizes. I can run a job of 4,000 images perfect. The next job with out openeing a paper tray will jump around within 5 pages. I can run for several days no jumping.
    Any ideas?
  • copytechman
    • Nov 2008
    • 966
    Side to side or lead to trail?
    Regards!
    A.
    • Calculated Design
      C6500 5mm jump
      Side to side. Lead edge is fine.
      • copytechman
        • Nov 2008
        • 966
        Assuming tray side guides are good, is machine power stable? lsu/hsync problem? Or even possible main board? Any sort of pattern @ all?
        Regards
        A.
        • Calculated Design
          C6500 5mm jump
          No real pattern. Everytime I think I have it fixed it comes back.
          I get no errors or any other issues.
          • totoro
            • 568
            Does this happen from all paper trays? If it only happens with the 2 tray LCT then turn dip switch 26 bit 4 ( I think )to the opposite of what it is. Auto image centering from LCT.
            Totoro
            • Calculated Design
              C6500 5mm jump
              When I disable the PF/ADU centering sensors the problem stops.
              Both trays 4/5 have the same issue.
              When you disable the senors you loose 2mm on the side to side registration. Pretty tough to print buisness cards with the sensors disabled.
              • Si@danwood
                • Mar 2008
                • 154
                I have seen this happen when the pb side guides are "out of synch" Check that the arrows align on the "synch" gear underneath the paper lift plate if they are out by just one tooth i have seen exactly what you describe here occur..Si
                • random
                  This is without a word of a doubt poor paper guide setting or your customer is cutting the paper to narrow or too short to what they are actually setting the tray to. The paper could be either 1mm too narrow or too wide for this 5mm shift to happen. DO NOT leave the back guide static and move only the front guide the two MUST move together.
                  There is nothing wrong with the machine it is performing normaly.
                  • StormyKnight
                    • Dec 2008
                    • 50
                    Yes I have noticed the guides being out of centering especially on tray 4. In my machine it shows up instantly as 12x18 rather than SRA3.
                    The thing I can't work out though is how is the customer getting it to jump a tooth. Nothing I tried would make it do it & I have to remove the circlip, support guide & gear to realign.
                    • random
                      Your customer is 'throwing' reams in the tray, quite easy to jump a gear.
                      • StormyKnight
                        • Dec 2008
                        • 50
                        Yep that is quite possible, went to the machine today & all is fine, perhaps me showing them last time that it is impossible to happen has stopped them doing it?
                        • Calculated Design
                          Still Jumping
                          I aligned both trays. Red dots and arrows on centering gear. Does anyone have any other suggestions.
                          • StormyKnight
                            • Dec 2008
                            • 50
                            Hope these few pages help, its all I can find on this issue....
                            • dudley
                              • 84
                              We have had this problem on a couple machines and have found the following
                              1 Clean the centering sensor and the black plate below it( if the paint is worn use felt marker to blacken the plate)
                              2 Clean all rollers in the PFU and check the bushings in the white rollers
                              3 Level the PFU to the body of the copier, then put a level on the vertical frame below the front mounting pin. If its not level then grab the bottom frame and push or pull it level(YES IT WILL MOVE EVEN WITH THE FEET PLANTED AND ALL THE WEIGHT ON IT) We have shifted the centering by as much as 4 mm with very little effort by pulling this to level the vertical frame. Because the mount points are so high if the frame is not vertically level then what you find is that you can shift it but if you move the bottom one way then the top will go the opposite direction. These units need some way of attaching the bottom frames of the copier and the PFU so the customer cannot move them by just shutting the drawers(3000 sheets of paper is like hitting it with a sludge hammer).
                              4 The main problem is that the stock locations of the mounts are fixed with no way given to adjust the true center of the trays to the true center of the copier. The only centering is done with software adjusting the position of the image but this breaks down when you exceed the maximum range of the sensor and you get the 5mm shift. Even the good old DI620 had a screw to adjust the manual centering of the bottom paper tray. We have tried to shim the trays themselves but due to the drive couplings and electrical connectors, this will not work
                              5 We have , on one machine as a test, modified the mounts for the PFU by slotting the holes where they attach to the copier to allow for manual centering of the PFU to the body of the copier. The adjustment is done by turning off auto tray centering and setting the tray centering to 0 on both trays. Then adjust the body of the PFU to the body of the copier to give the best average centering of both tray 4 and 5. Then turn on the auto centering and adjust both trays for proper centering. This PFU also now has a third mount plate from the bottom frame of the copier to the bottom frame of the PFU( crude but effective) To date this has fixed an ongoing problem with this machine but it has only been a few weeks.
                              This is what our team up here has seen and what we have tried so far.
