BIZHUB C353
  • thuo
    • 155
    BIZHUB C353
    Bizhub c353 showing c2152 .replaced a new tranfer belt.tried trouble reset code still persists .anybo0dy with a sugestion
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Check the position of your transfer belt, and the retraction sensor. You should be able to reset buy opening/closing the front door.
    Parts: Its what your copier craves!
    • copytechman
      • Nov 2008
      • 943
      If thats a no go then you may have to replace the retraction sensor assy as they (KM) changed the shape of it to deal with this issue (to say the least). Not a fun item to get to either.
      Regards!
      A.
      • thuo
        • 155
        error has disappeared but printing a test page black colour does not come out.then other colours in the printed images comes out overwrapimg
        • thuo
          • 155
          urgent please .i am stuck
          thanks
          • ni311
            • May 2008
            • 658
            What do you mean by "test page black colour does not come out"?
            Did you try to make a gradation adjust?
            • thuo
              • 155
              What i mean is the does not print or photocopy in black .and the other colours comes out with distortion sort of double image
              • abilashvk
                • 61
                friend,
                Transfer belt has got seperation rollers for each IUs respectively inside it,which helps to produce images respectively on it.try to find if something is out of position inside, or take an old unit (if available). try that one in this machine, confirm, observe both belts carefully & there you are
                • ni311
                  • May 2008
                  • 658
                  I believe you're talking about the transfer roller and not separation roller...
                  • Cantechman
                    • Nov 2008
                    • 228
                    I saw that error one time, it was the wrong screw put back that holds the belt bracket in place. Make sure the screws are the same length as the ones that came out.
