help b421 jamming at registration
  • tarzak911
    • 55
    cassing the paper 1 and 2 are ok but the lct it is creasing and making waves....in paper.
    changed registration unit...
  • copytechman
    • Nov 2008
    • 947
    Try washing the lower relay clutch, thats the one just below the reg unit on the vertical transport, i believe it comes out with the tray 1 feed roller unit.. Had some good success with that..
    Or.. b4 doing that try adjusting the printer resist loop in service mode for the tray in question.
    Regards.
    A.
    • copytechman
      • Nov 2008
      • 947
      Regards.
      A.
      Edit: by washing I mean with 99% isopropyl alcohol. And then drying it out..
      • mo0651
        • 1054
        Did you replace both clutches in the registration unit? I've never seemed to get only one to fix the problem.
        • copytechman
          • Nov 2008
          • 947
          I have also done that in the past but found it wasn't either of em, it was the relay clutch that fed the reg unit not letting go (sticking) causing too much buckle etc etc
          Regards!
          A.
          • tarzak911
            • 55
            thanks guys found da problem... tried what u said....problem was black door pawl cracked ...took some time to find this1....
            • tarzak911
              • 55
              b421... jamming... got this one tried everything....
              check for cracaked door pawl not closing proerly... thx 4 your help.
              • copytechman
                • Nov 2008
                • 947
                Cool will do that as well...
                Regards!
                A.
                • avanza
                  it is very common for bizhub 420/500 to have paper jam around the registration units. The cause of this is actually the adu clutches is 'slip' by the greese. just clean it up with alcohol or replace.
