Konica Minolta C250
  • JSC
    Gimp
    • Dec 2006
    • 618
    Konica Minolta C250
    Data light flashes, you can ping it but does not print. I have done a nic & nvram recovery, and it is on v3.05 firmware. Customer is chargable and very nice so i do not want to throw boards at it if i can help it.
    All help appreciated.
    The gene pool could use a little chlorine.
  • copytechman
    • Nov 2008
    • 969
    Did u actually reflash the machine firmware?
    Regards!
    A.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Regards!
      A.
      Yep.
      • mrwho
        Major Asshole!
        • 4299
        DESCRIPTION: Unable to print. The data light blinks but no document prints (including a test page). SOLUTION ID: 238248
        SOLUTION: CAUSE: Incorrect Image Controller setting.
        SOLUTION: Set the proper Image Controller setting. To set the Image Controller mode, perform
        the following:
        1. Enter Service mode.
        2. Select System 2.
        3. Select Image Controller setting.
        4. Select Controller 0.
        5. Select End/Exit to exit the service mode.
        Mascan42
        Ibid
        • copytechman
          • Nov 2008
          • 969
          K, no codes in machine (account tracking or anything?)
          A.
          • copytechman
            • Nov 2008
            • 969
            Heh Beaten! What mrwho said!
            Does it show in the log/job history?
            Regards!
            A.
            • JSC
              Gimp
              • Dec 2006
              • 618
              the following:
              2. Select System 2.
              Ok, it was set on Controller 3, so now i have selected controller 0 and entered that..............................now the networksettings button has disapeard.............
              • mrwho
                Major Asshole!
                • 4299
                Wait a couple of minutes... it's probably reinitializing...
                Mascan42
                Ibid
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  Yea i was just being an arse machine is now up and running thanks dude, i'll add to your rep.
                  Although the 20ish year old chick here is so happy now she says if you can pop over she will take you out for a few drinks
                  I think the taxi might be a bit pricy!!!!!!!!!!!!!
                  • mrwho
                    Major Asshole!
                    • 4299
                    Thanks. Tell her I'd like to, but I'm a little bit far away - although if I ever go to the UK (about 1000miles), I'll call you to charge that drink!
                    Glad it worked. Cheers!
                    Mascan42
                    Ibid
