IC-402 Fiery Controller Not Working
  • pajeroid
    • Jul 2009
    • 130
    This Fiery just does not come on to ready. I have hooked up a monitor to the Fiery box to see what is going on and the display reads....
    Uncompressing Linux
    Ok, booting the kernel.
    Then it just hangs. It mentions something about Lilo.
    I have the system software CDs(2) but they will not find the Fiery either.
    Any advice?
  • mrwho
    Major Asshole!
    • 4299
    You say they will not find the Fiery. How are you trying to install the system? I never personally installed the system on a 402, but I assume it is done via the parallel port with the copy command or similar?
    Mascan42
    Ibid
    • pajeroid
      • Jul 2009
      • 130
      You do it with either a network cable (crossover) or USB cable (A to B). In my mind, unless the Fiery boots up to Linux or something similar it won't be able to update the software?
      LILO is linux, do you think if I install Linux it will find it again?
      The Fiery software says... Waiting for Fiery to become ready.....
      Then times out.
      • Emjay
        • Jul 2009
        • 42
        LILO is the boot loader.
        I thought the system software for this Fiery was installed from a bootable CD on a connected laptop.
        ie. Burn the software iso, then boot your laptop from the CD. This loads a version of Linux (may even be a Knoppix clone) which then allows you to re-install the system software to the Fiery.
        It does rather sound like a corrupt software install, or a failed hard drive.
        I've got the system software CD pdf and the service manual for this controller if you need it. Send me a PM !
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Maybe this will help, Note the changing of service switches.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
          • pajeroid
            • Jul 2009
            • 130
            I've pretty much done everything as described in that doc file - but thanks, at least I know i've done everything correctly now!
            I now have a blank HDD of the same size and kind - so where do I begin now!?
            The screen displays....
            "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER."
            • pepper38_cnd
              • Aug 2005
              • 1075
              If you have tried every thing else I would try the Flash drive reload.
              Also when you tried your install make sure you used "installer.vbs" not "installer.exe"
              • pajeroid
                • Jul 2009
                • 130
                OK Pepper - that sounds like it could work - but I need the USB Flash Tool CD to boot from. Do you know where I can get it from?
                • pepper38_cnd
                  • Aug 2005
                  • 1075
                  Send me an email I'll send you a YouSendIt link. info@iuresets.com
                  • pajeroid
                    • Jul 2009
                    • 130
                    Right, just to keep you all updated.....
                    I've tried the USB Flash Tool and got a bit further - it did try and boot from the USB drive, but then hung at the same point as my initial problem (Uncompressing Linux.....................Ok, booting the kernel.)
                    But this time it reboots after about 7 seconds.
                    I'm now trying to format the HDD as i'd installed a version of Linux onto it (why, i'm not quite sure - but at least I know the HDD functions OK).
                    I had to burn the USB Flash CD at a low speed (8x) as when I burnt it at 24x it came up with an error (err 2).
                    • pajeroid
                      • Jul 2009
                      • 130
                      Right well after fully formatting the HDD for about 4 hours.... It still does the above.
                      Boots from the USB Drive fine - but then just reboots. I'm going to try and find another USB Flash drive and try that next.
                      • time2fly
                        • Jul 2008
                        • 134
                        did you low level format the drive? It shouldn't take 4 hours to format, maybe to system software. Try low level formatting the drive, go to this site to get the free software. I've used this to salvage many HDD and to use bigger drives in the fiery's.
                        HDDGURU: Laptop and Desktop Hard Disk Drives, Tests, Software, Firmware, Tools, Data Recovery, HDD Repair
                        • RyanPacific
                          Linux Ninja
                          • 97
                          Just a thought here. When you open the case to the IC-402 look for a jumper near the system battery and CMOS ROM chip and see if there is a way to reset the unit (usually it will say 'RST' next to it). I have done this on quite a few controllers from EFI and some Toshiba stuff i.e. GL-10x0 and I have had fantastic results. After you try this if it still does not work pull the memory out of the Fiery and run a memory test on it. You will need to install the memory in a compatible device with a CDROM boot capability. Use Memtest86, you can get it here: Memtest86.com - Memory Diagnostic. If there is a ton of errors replace the memory.
                          Service Business Equipment
                          New, Used, Refurbished Copy Machines and Printers
                          Copiers in Seattle, Kent, Tacoma and Bellevue
                          • pajeroid
                            • Jul 2009
                            • 130
                            I've had a look inside and theres no reset jumper - only a CMOS reset which i've already tried. The only other jumper is an intrusion detection jumper which I presume is unused.
                            I've run a memory test for 2 hours and no errors were found with Memtest 86.
                            I've also tried the low level format which finished successfully.
                            I've ordered a USB Drive that was recommended in that word document above to see if that is the problem because my USB Drives are dirt cheap ones.
                            It still just turns off after about 30 seconds with the display reading....
                            Uncompressing Linux.............Ok, booting the kernel.
                            • Herrmann
                              • Jan 2006
                              • 792
                              As next step, i would try a "Knoppix" CD and look, if the system comes to live.
                              Did you already replaced the hd?
                              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
