c300 with code c2152
  • copiers4africa
    • Jul 2009
    • 47
    pls help this machines was running fine until we changed black image and colour drive units.. it is now 600 copies later and this code has come up..has anybody had this on this machine..what must i look for.
  • prasad
    • Aug 2009
    • 12
    Carry out your transfer belt Mod. Also reinforce the bracket.
    • mitchl
      • Apr 2007
      • 501
      Here's another posible? Hey you never know. Have you done a trouble reset just for shits and giggles?
      Subject:
      C-2152 (C2152).
      Description:
      C-2152.
      Solution:
      CAUSE: In addition to the causes listed in the Service Manual (1st Image Transfer Pressure/Retraction Position Sensor, PC6; Main Motor, M1; the 1st Image Transfer Pressure/Retraction Clutch, CL3; and the Mechanical Control Board), check for paper stuck in the paper path. For example, paper in the fuser section could block a sensor causing the C-2152 code.
      SOLUTION: Remove any paper stuck in the machine.
      • copiers4africa
        • Jul 2009
        • 47
        thanx guys will try everything u have suggested and will let u know..
        • MadCityCopy
          ieeeee
          • Oct 2010
          • 58
          Re: c300 with code c2152
          What is the transfer belt mod? I have a C-253 blowing this code after I replaced the T-Belt.
          • backspace
            • Jul 2009
            • 54
            I have same problem on C252, When I remove bypass machine is working.
            I later found damaged wires on Bypass paper feed clutch (CL5)
            • kingarthur
              • 1385
              when you say you changed the drive units, are you talking about the units at the back of the m/c, if so...did you remove the fuser drive unit, on the C352 this also drives the transfer belt, if you've lost the spring from that drive unit, you'll get a c 2152 error
