C350 with FS-601
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    C350 with FS-601
    Having a strange problem - We have a C350 with a FS-601 finisher. When the finisher is hooked up, the machine will not duplex. When we take the finisher off, the machine functions just fine. We have checked all the sensors, board connections, etc..., and just cant figure it out. Has anyone ever had a problem like this?
    Parts: Its what your copier craves!
  • Kmdurrin
    • Dec 2008
    • 132
    Update: We tried swapping the finisher with another FS-601, and the same problem came back. Could this be a switch setting in the machine? Firmware? I am totally stuck.
    • manuelcorrea
      • May 2009
      • 46
      c350
      where is it counting jams? have you tried running it without the finisher?
      • manuelcorrea
        • May 2009
        • 46
        c350
        it has to be something in the fusing unit/ exit section!!
        • Kmdurrin
          • Dec 2008
          • 132
          The fusing/exit section was the first thing we checked... no problems there. When the finisher is removed, the machine works perfectly. We only have a problem when the finisher is attatched. The paper doesnt jam anywhere... its like the machine just forgets how to duplex.
