Firmware Imaging Toolkit
  • xpress
    • Jun 2008
    • 63
    Cannot find. I know I can get it from Onyx as a tech, but trust me, I log in and its not under my search menu as a sales person, all the other software, ftp, anything is there.
    Any links or PM?
  • aidil rashidi
    • Jun 2008
    • 33
    try this link...
    Konica Minolta Australia
    but i think you need to register to login
    • mrwho
      Major Asshole!
      • 4299
      I personally never liked the toolkit - unless it has gotten much better since the last time I used it.
      I very much prefer mini-cygwin, it is (or used to be) much faster and error-free - why don't you use that instead?
      Mascan42
      Ibid
      • Bizwork
        • Mar 2009
        • 16
        Hi
        If you go to this link you can have a copy of the Toolkit.
        RapidShare: 1-CLICK Web hosting - Easy Filehosting
        • xpress
          • Jun 2008
          • 63
          I downloaded cygwin and got it all, but when i go to write the firmware to a drive letter i type in like C:, Non removable, good,
          So i type E: (for my CF card) and I get a bunch of crap unreadable txt, not sure if it is a bad install or a bad command but whatever.
          • mrwho
            Major Asshole!
            • 4299
            You're using Mini-Cygwin or the standard Cygwin? The standard one will not work, AFAIK. You need the mini-cygwin version.
            Mascan42
            Ibid
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              Which version did you use? I have the latest and it works fine. As to where to find it, it should be located with the firmware downloads. Most sales people do not have access but some do.
              • aidil rashidi
                • Jun 2008
                • 33
                i use ver 2.5.5 and it works fine. it only give problem if you use a high speed CF (e.g 80x and above) for fw upgrade.below are the supported models:
                bizhub C250/C252/C300/C350/C351/C352/C450
                bizhub C250P/C352P/C450P
                bizhub 200/250/350
                Di1810/1810f/2010f/2510/3010/3510/2510f/3010f/3510f
                bizhub C650/C550/C451
                bizhub C353/C353P/C253/C203
                • xpress
                  • Jun 2008
                  • 63
                  Damn, lexar 512 not working have to be a 256mb sandisk?
                  • mrwho
                    Major Asshole!
                    • 4299
                    I only had success with cards from ExtreMemory (or however you write it), 128Mb and 256Mb. Tried it with a Kingston 256Mb without success.
                    Trouble is, it's hard to find compact flash cards nowadays, and even when you do, rarely they are bellow 2Gb.
                    Mascan42
                    Ibid
                    • copytechman
                      • Nov 2008
                      • 947
                      True nuff! I have 2 cards (256 and 128mb) and only the 128mb card works on everything! (Its a verbatim cf card!)
                      Regards!
                      A!
                      • mrwho
                        Major Asshole!
                        • 4299
                        I had an idea: what about a list of known working and non-working CF cards? I started a new thread here. Send your feedback and I'll update it. I'm sure it will come in handy.
                        Mascan42
                        Ibid
