c350 c-12c0 reset
  • cantonakis
    • 19
    c350 c-12c0 reset
    After changing the HD on the fiery the code c-12c0 keeps comming up when the machine boots. The controler boots fine and the new disk. I change the fiery from another machine and this code keeps comming up.
    Does anyone know who to reset this ?
  • xpress
    • Jun 2008
    • 63
    Does it start or not? Try disabling it, installing it, and then enabling it.
    • copytechman
      • Nov 2008
      • 955
      According to the book thats the code for the hdd mounted to the mfp board, not the fiery.. check that!
      Regards!
      a.
      • cantonakis
        • 19
        ok I solve the problem
        In the system incoming, HDD , the HDD it was set to SET so I change it to UNSET and the problem went away.
        Thaks to all of you
