Konica Minolta 350 Bizhub C2557
  • Deka
    • Aug 2009
    • 15
    replaced drum cleaning blade now i have C2557 code. cleaned sensor and replaced developer and still have code. any ideas? thanks
  • D&F
    run F8
    • Deka
      • Aug 2009
      • 15
      Konica 3550 with code
      Thanks I will give it a try
      • krm
        • Aug 2009
        • 233
        I have always had to replace drum unit and developer as a set, or 2557 code appears. Clear pc counter and run f-8.
        • copytechman
          • Nov 2008
          • 946
          I concur with this!
          A!
          • Deka
            • Aug 2009
            • 15
            konica 350
            That worked these copiers are driving me crazy with that code What causes this and the drum looked good. I replaced all 3. Is there anything i can do to prevent this?
            • backspace
              • Jul 2009
              • 54
              first open the duplex door
              than turn on machine.
              it will show door opene.
              go to service mode - funcion - f8
              Close door and press f8.
              PS
              First must clear in special parts counter for PC drum.
              • Si@danwood
                • Mar 2008
                • 154
                Try reseting drum counter then setting ATDC vtge to around the 85 mark!.Run machine up and test about 100 copies to make sure code doesnt return! Saves on a drum and dev!!!!...Si
                • chexin51
                  • Aug 2008
                  • 37
                  you might have to clear image memory first
                  bizhub 350
                  Sometimes the machine jumps into code before you can clear counters and perform F8 calibration because it wants to print a fax or print job in memory as its first priority. here was the solution that worked - thanks Tech Support Montreal for your patience and solid advice.
                  Problem: glue on drum and cleaning blade was leaving lines on copy
                  I removed front side cover of drum unit, removed drum, cleaned CL.BL.
                  but when I put it back in copier, I got a C-2557 code = toner sensor not reading Dev
                  even after new drum unit, new dev unit, new dev was installed same code
                  Solution: the following procedure was successful
                  1. Clear Image memory - docs trying to print ( fax or print job )
                  at warmup a small + sign appears a left of display - Press 3
                  select Clear Image Data option
                  Enter 8 digit serv. code ( 00000000 ) / End
                  Image Data Clear/Yes.
                  Exit to get out and turn off/on Main Switch
                  2. in Service Mode - Clear Special Parts counter
                  select IU and Dev then C to clear
                  3. then replace units physically
                  4. if dev is replaced - Tech.Mode - Function - F8 - Start
                  dev will calibrate in 2 minutes
                  • backspace
                    • Jul 2009
                    • 54
                    OK
                    1. Clear counter for drum
                    2. Turn off machine.
                    3. Open side dore (or duplex door)
                    4. Turn ON machine
                    5. It show ,,side door open,,
                    6. Go to Sevice Mode
                    7. Find in Function F8
                    8. Close side door
                    9. Run F8
                    10 wait to start button blink green
                    PS
                    If parts all new with dev. DV310
                    • Deka
                      • Aug 2009
                      • 15
                      Hey guys Thanks!! It is working and i have printed your suggestions out but I have a bigger problem with a 7145 that I am just about to post maybe you can give me some clues on it before I say Enough already with the copiers LOL
                      • don
                        Hi all,
                        I am running KM c350.
                        Can anyone tell me what is function F8.(RunF8)
                        How does it work, and what is the reason behind
                        it to run F8.
                        Does this reset the IU Life counter?
                        I appreciate if anyone can provide me in detail on this.
                        Regards.
                        • ck1
                          • 485
                          Originally posted by don
                          Hi all,
                          it to run F8.
                          Regards.
                          Hi,
                          this C350 no have F8 ,counter Iu can't reset as manualy,two chioce
                          1.change new Iu
                          2.change the iu chip (T&C Apply )
                          Good Lucky
