Better make sure it's the motor (u can swap with other motors w/same pn# in this machine to test!) Cuz sometimes its not... often it is a control board icp failure.. repaired a few of those!
DESCRIPTION: F51-02. The fixing motor M11, will not turn in diagnostics. CAUSE: Loss of 24VDC to the Fixing drive motor.
SOLUTION: Replace the PRCB (p/n 40LA-9029).
Try this, could be that the motor is OK. Check the ICPS on the PRCB before ordering a new one, as copytechman said.
' "But the salesman said . . ." The salesman's an asshole!' Mascan42
'You will always find some Eskimo ready to instruct the Congolese on how to cope with heat waves.' Ibid
From a previous post, it was advised to replace the Corona unit in conjunction with the main board. Does this seem logical, or will the main board correct the problem?
