Bizhub 250 c0202
  • Copychick
    • Oct 2008
    • 19
    Bizhub 250 c0202
    I managed to clear the code after the customer got paper stuck behind the drawer. But when I opened and closed the first drawer I can hear it keep trying to lift the paper then it codes again. I swapped the second and first paper drawers and it's working for now, but I need to know which parts to order. Should I get the lift motor assembly, is there an upper limit switch?
    I don't normally work on Minoltas, can anyone help? Thanx!
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Description
    Unable to clear a C-0202 code.
    Solution
    CAUSE: Tray 1 elevator failure; the lift up sensor is blocked.
    SOLUTION: Check PC2 and PC3 for foreign objects in the way (usually a piece of torn paper).
    Parts: Its what your copier craves!
    • minimerlin
      • 851
      Did the fault shift with the tray? I have found that the black plastic rear bushing on tray lift bar can break and move causing the shaft to drop out of connection with the drive on the machine, also the trays tend to crack at the front right corner..due to users using too much force when closing them.
      Please do not PM me without asking first.
      • Juggy
        Technical Support
        • Sep 2007
        • 101
        Hi if the error code repeats now in Tray 2 as c0204. then replace the Cassette 4030320109 which is the just the base frame. or 404001560D CASSETTE ASSY. or just use the modification plate 4030P00100 Reinforce plate B 250/350
        on the cracked tray.
        • Copychick
          • Oct 2008
          • 19
          The second cassette tray which I put in the first drawer lifted ok and first which is now in the second lifted without coding. They don't sit correctly side to side with the covers. I should go back and check the drawer all little closer to see if anything is cracked. Thanks for the help, I'll update after going back!
          • minimerlin
            • 851
            You can adjust the drawer fronts to align very easily..look at the mounting screws and you will see two arrowed positions..just take out the screws and refit the front in the correct position for the cassette position you need.
            • hmidani
              • Mar 2010
              • 2
              Originally posted by Kmdurrin
              Description
              Solution
              thank you, it was a piece of paper
              • Tuks
                Re: Bizhub 250 c0202
                I'm facing the same problem and have removed the paper from the back of the tray, check the connection. But still it says tray 1 failure. Is their any reset function
                • CraigW
                  • Dec 2010
                  • 417
                  ^^^^ Did you Off/On the main switch ??
                  • tech51
                    • 846
                    Open/close the front door? Oops that's for a c250 apologies. Could try open/close the right hand door.
                    • Tuks
                      Yes Craig on/off but still tray 1 failure, even change tray 1 and tray 2, off/on and still tray 1 failure.
                      • tech51
                        • 846
                        Seriously have you opened and closed the right hand door with the machine switched on? Generally on km machines opening and closing the doors clears the codes. However if that doesn't work then you either have a broken tray or lift motor.
                        • CraigW
                          • Dec 2010
                          • 417
                          Rank B "opening & closing the front door" for 0202.
