Konica 7022 code F4611
  • Rick Martinez
    • Sep 2009
    • 77
    I need to figure out what this code means the only thing I got is that is an AGC error could anyone help.
    Rick
  • SAR
    • Jul 2009
    • 203
    Do you get the code during warmup? Check that the white reference strip on the underside of the platen glass is clean and positioned properly.
    It could be a bad exposure lamp. Go into 47 mode, output 00 and the lamp should come on if it's good.
    If it happens intermittantly during copy runs it could be the A/D ribbon cable, scanner motor or DC power supply.
    • strider5555
      • Jun 2008
      • 96
      In my experience, it is the inverter board for the lamp, inv1. Replace that and you should be good.
      • Rick Martinez
        • Sep 2009
        • 77
        Thanks SAR and Strider for your support, i got it working by cleaning the white reference strip under the glass it.
        Rick
