DF-605 paper jam on last original
  • blago_vd
    • 38
    Hello everybody,
    I have a problem with DF-605 mounted on Bh350. The machine indicates paper jam on DF when the last original passes through. There is no real jamming in the DF. The problem occures very often. I cleaned all sensors. Please if anybody has a solution help.
    Thanks in advance
  • moonwalker3778
    • Jun 2008
    • 87
    check a small mylar sheet exact opposite to pre scanning sensor, it may be deformed.
    • krm
      • Aug 2009
      • 233
      Originally posted by blago_vd
      Hello everybody,
      Thanks in advance
      torsion spring pn/4344505901 is broken and needs to be replaced. A little piece breaks off and causes jams. It is located in the back and takes 1-2hrs to replace.
      • Hansoon
        • Sep 2007
        • 3401
        Or too much grease in the torque limiter spring. Clean part# 4344-5203-01 and 4344-5202-01 Hans
        • blago_vd
          • 38
          But there is no jammed original, only indication, and always on the last sheet. After opening and closing the cover of the DF the jam indication is cleared.
          • moonwalker3778
            • Jun 2008
            • 87
            did u cross checked my suggestion?
