BizHub FS 606 saddle stitch skew
  • Desert Rat
    • May 2008
    • 1089
    I ran into this on an install today. But the customer noticed, the corners
    don't match when folded and/or stapled, during saddlestitching or just
    folding.
    I cleaned the rollers with a damp rag. I could not see an obvious
    adjustment for the gate that holds the paper for saddle stapling.
    I adjusted the fold and fold and staple adjust in 36 mode, no luck.
    I did not have a lot of time to spend on this today and will go back
    tomorrow, time permitting.
    Any pointers before I go? I have not had the opportunity to work on
    a saddle stitcher fold problem before on any model. Meanwhile I will read
    through the book.
    Thanks for any help
    DR
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Most of the folder/staplers do have a mechanical adjustment for the backstop.
    Is this a "floor" model, with a pull-out fold/staple unit?
    If yes, pull the unit out on the rails, and flip down the narrow metal plate with a green plastic label. You should be able to see two millimeter scales. Loosen the screws and move the backstop to correct the skew.
    • Desert Rat
      • May 2008
      • 1089
      Setright,
      Yes it is a floor model. And I remember seeing that flap you mentioned.
      I may get a chance to get back there today. I will check it out.
      Thank you very much
      DR
      • Desert Rat
        • May 2008
        • 1089
        Setright, sorry to so long in getting back to this, but I did want to
        thank you for the right info. I was able to go back and make the
        adjustment. This corrected the problem.
        Thanks again
        Dr
