C250/C252 Transfer Belt reset help
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    This is a problem that has plagued our service department for a while. I am new to the site and thought I would see if anyone out there can assist me. We have reset transfer belts on other color Bizhub models (C350, C450, etc) by simply replacing the fuse, but that does not seem to work on the C250 & C252 models. The "replace" message is still there after we replace the fuse. Has anyone else had this problem? Is there something that cams upon installation that lets the machine know that there is a new unit? Any insight would be greatly appreciated. Thanks.
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Absolutely nothing special about the procedure, we use the same fuses as per the c450, 350 etc. Never ever had a single problem.
    just ensure you are using the correct rating fuse, that’s going to be your problem, haven’t got one on hand at the moment to check its value.
    • copytechman
      • Nov 2008
      • 947
      Same as prior poster, we use the same fuse for the 8031/c350/c450/c250/c252/c352 and the c451 and c203 series.... a 1/16 amp glass fuse... worked every time unless I used the wrong rating fuse by accident!
      Regards!
      A!
      • OBXtech
        \tek-ˈni-shən\
        • Sep 2009
        • 37
        OK...so I cracked open 2 transfer belts. One is for a C250/C252 and the other is for a C203/C253. The C250 transfer belt has a 200mA fuse and the C203 belt has an 80mA fuse. Interchangable? I wouldn't think so, but maybe I'm crazy. Will the 80mA work in place of a 200mA? From what the last 2 posts state, then my answer is "yes." In my mind this doesn't work, but then again, my mind has let me down before...
        -Thomas Alva Edison
        • emujo
          • Jun 2009
          • 3009
          Fuses are available at http://www.digikey.com/
          Transfer Belts
          Replace glass fuse 80ma , counter resets automatically.
          Item # 507-1218-ND is the fuse to blow the transfer belts up to C650
          Fuser Units
          Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
          Item # F2307-ND
          Hope this helps Emujo
          • joeyl328
            • Sep 2009
            • 15
            help
            So how do you replace the fuse? I have read a few posts about how this will reset the "replace transfer unit" warning, but no one has really said how to get to it. Where is the fuse? Thanks
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              as you stand at the front of the machine and slide the transfer belt out, its hidden in the front corner of the transfer belt assembly. you need to loosen the top plate with the separator, remove the side plate with 1 screw and one E clip and a spring. you then have access to the little black cover with 2 contacts, you need a precision philips screw driver to open it. the fuse is in that black cover.
              • joeyl328
                • Sep 2009
                • 15
                80 ma fuse???
                Where can I find a 80ma fuse? I checked 3 hardware stores and radio shack, the lowest rating I can find is .315 amp. Will that work?
                • pepper38_cnd
                  Field Service Manager
                  • Aug 2005
                  • 1075
                  joey I would not chance using a 315 MA fuse. The OEM Fuse in Canada is a 1/16 A or 62MA we use 63MA fuses because they are readily available, I have been told you can use anything from 50MA to 200MA I personally would try to stay as close to the OEM as possible.
                  Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                  Now into Ip TV KODI Boxes
                  • copytechman
                    • Nov 2008
                    • 947
                    You can get them from digikey... thats where mine come from (both types, the pico and the glass ones.)
                    Regards!
                    A.
                    • joeyl328
                      • Sep 2009
                      • 15
                      so one final question: a friend of mine brought over 200ma fuses, will that work, or is that still too high? I've seen some posts saying it is ok, but I just want to make sure...
                      • clueless
                        Bizhub C252 Transfer Unit
                        When you refer to "the front of the machine", do you mean where the toner is loaded or the side that drops down to locate the rollers and release paper jam?
                        • clueless
                          Help!
                          Please tell me where to find the transfer unit. When you say "the front of the machine", do you mean where the toner is loaded or do you mean the side where the rollers are to clear paper jams?
                          • DadO
                            • Dec 2007
                            • 403
                            I would not go whit 0.200 mA fuzes! I tried 0.100 mA on c352 and it is working but i don't recommend (i was bit in hurry and didn't have 0.80). Try to find or 0.80 mA (or 0.080A) or lower to be a safe. On c353 series, don't go anything above 0.80mA!
                            • 8050
                              • 88
                              Yes, the right hand side. Pull down the transport section and there are 2 screws that hold the transport belt locking plates. Remove the screws and pull the plates out a bit. Now you can remove the transfer belt unit.
