C500 Error codes
  • doomblack
    • Aug 2009
    • 12
    C500 Error codes
    can someone send me a error code PDF list for Bizhub c500,
    or any information on sc34-01.
  • Mikey
    • Sep 2009
    • 54
    Konica Minolta C500 sc32-01
    For sc 32-01 check the fixing cooling fan 1 & 2. There may be abnormality in the detection signal on either of them continuously for specific time.
    For sc34-01 you may have problem with high temperature. Check TH1 in the fixing unit.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
      from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • doomblack
        • Aug 2009
        • 12
        thanks, but in theory wouldnt it start up after it cools down?
        • Mikey
          • Sep 2009
          • 54
          You got a point but first check the thermistor TH1 in the fixing unit. Is it good or bad? Replace if bad. Check the clearance and remove any dirt on this sensor.
          Try this:
          Enter 25 mode press 5 (parts counter). On the part counter menu screen press 1 (count of special parts) then on the parts counter screen select the part that you want to reset. Press Count Reset then press yes.
          • wolekraft
            • 22
            What is thermistor TH 1
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              If you do not know what a thermistor is, call a service tech.
              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
              ---Groucho Marx
              Please do not PM me for questions related to Konica Minolta hardware.
              I will not answer requests or questions there.
              Please ask in the KM forum for the benefit of others to see the question and give their input.
              • remati
                • 149
                • RRodgers
                  • Jun 2009
                  • 1947
                  Nope, any fuser code locks the machine down and has to be reset.
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Try this:
                    This won't help your problem.
                    • Mikey
                      • Sep 2009
                      • 54
                      Bizhub C500
                      @doomblack; Yes you must let the fuser cool down so that you can troubleshoot the fuser assembly.
                      @Wolekraft; You must have proper training to be able to the work follwing the RIGHT procedure. TH1 in reality was a thermal switch. I don't know why manuals refer to it as thermistor. Anyway, there is a thermistor touching the fuser roller. Check it using an ohmeter. It is bad if open circuit. Thermal switch maybe shorted even you exposed it to high heat...replace it if that is the case.
                      @RRogers; Yes, fuser trouble codes must be reset after replacing the busted part/s.
                      • RRodgers
                        • Jun 2009
                        • 1947
                        thanks, but in theory wouldn't it start up after it cools down?
                        Nope, fuser error's on copiers will lock in and require a reset.
                        Did you just have the heat tube or pressure roller replaced? Usually the thermistor on the end get's bent away and doesn't touch the roller. This usually happens when and inexperianced person puts in these rollers.
