Bizhub C450
  • stevee104
    • Mar 2007
    • 214
    Bizhub C450
    Have a machine that color is off from front to rear of machine,have clean the leds or lens,replaced all iu's did a initialisation and stabilization and still can't get to balance out. The front of the copy is fine its the back of the copy that is off.
  • RRodgers
    • Jun 2009
    • 1947
    Sometimes the LED units don't go all the way up when you move the blue handle to lock in the IU's (image units) I think that's been a problem here and there with those boxes, although I've never seen it.
    • mabawser
      Tech
      • Sep 2009
      • 121
      Have you printed out the 4 seperate colours to see if they are all O.K or not?!
      Is it when your copying, printing or both?
      • stevee104
        • Mar 2007
        • 214
        it is both ways the colors are wash out to the backside.
        • Albonline
          • Sep 2008
          • 1153
          is this mechine reasonably level? are all 4 colors acting the same? what king of shape is the 2nd xfer roller in?
          • stevee104
            • Mar 2007
            • 214
            the yellow and cyan are the ones that are off,the magenta is not as bad and the black is fine.
            • minimerlin
              • 851
              Transfer belt problem?
              Please do not PM me without asking first.
              • stevee104
                • Mar 2007
                • 214
                Ok we will get one ordered and give that a shot.
                • Impulse
                  sorry .. cant make new topic
                  Have a problem with my C450P - error C-F023
                  I need install new HDD ? Can I reset my HDD ? Can this make without servis manager ?
                  • JtheCopyGuy
                    • Aug 2009
                    • 26
                    stevee - I've run into a similar issue where 2 inches from the edge of the paper the color is just washed out or almost negative. This shows the most during a Gradient print. What the issue was for us was a bad Cyan Imaging unit, which threw off any of the color grid that cyan was used for. I would try doing a Gradient and maybe even a solid page to see if this is 1 color causing the issue or several. If it's universal I'd look at Transfer Belt like everyone else has stated.
                    Impulse - are you installing a new HDD or are you replacing one? If you're replacing you can try to do a logical format, then if that dosn't work try a physical format followed by a logical format. If you are putting in a NEW Hard drive, make sure you have the HDD bracket and it's a relatively easy install followed by telling the C450 in service mode HDD is on, then logical format and you're set!
                    • Impulse
                      No, I wish to known it is possible or not to do without new HDD? On how many I know native HDD the given model has no?
