KM BizHub 162 : Error code M1 . Help... plzzz
  • copyguy5
    Guest replied
    M1 error on Konica Bizhub series
    The following is a description of the M1 process on the Bizhub
    M1 (main) is controlled by the PRCB (printer control
    board) and the motor drive power is supplied from
    DCPS2 (DC power supply unit 2).
    1. Operation
    M1 is a motor driven by 24V DC. It drives fixing
    upper and lower rollers, paper conveyance belts,
    and thick paper conveyance roller. M1 incorporates
    a speed controller circuit to send a signal
    indicating abnormal rotation to PRCB when the
    PLL lock has been released for longer than the
    specified period of time.
    M1 starts rotating when the START PRINT button
    is pressed and stops when the last copied
    paper has been ejected. During the warm-up
    operation, M1 rotates to rotate the fixing rollers.
    When either one of the front doors of this machine
    opens or closes, MS1 (interlock 1) or MS2
    (interlock 2) actuates to stop supplying the DC
    power to the motor, causing the M1 to stop.
    2. Signals
    a. Input signal
    (1) M1 EM (M1 to PRCB)
    M1 fault detection signal
    [H]: Abnormal rotation (PLL lock has been
    released for 2 to 3 seconds or longer.)
    [L]: Normal rotation
    b. Output signal
    (1) M1 CONT (PRCB to M1)
    M1 drive control signal.
    [H]: M1 ON
    [L]: M1 OFF
    Hope this gives some help
    good Luck
    copyguy5
  • nuakiepphong3
    Guest started a topic KM BizHub 162 : Error code M1 . Help... plzzz
    KM BizHub 162 : Error code M1 . Help me plz. Thank
