HELP GUYS Biz 500 with c-4701
  • bgkahuna
    • Aug 2008
    • 17
    Hey guys have you ever ran into a C-4701 code on a bizhub 500? Im hoping it isnt what Konica is telling.. They say its a write unit.. HELP GUYS!!! THANKS...
  • copytechman
    • Nov 2008
    • 947
    From da book!
    C-4701 Laser index abnormality.
    When the cycle of the index is different
    from an expected value.
    Index board (INDEXB)
    Overall control board (OACB)
    Yup, pretty much laser unit (or a component thereof)
    Regards!
    A!
    • bgkahuna
      • Aug 2008
      • 17
      Thanks bro,
      Actually I already have that document, but I was hopping for another answer. And different advice.. But thank you
      • masterteknicion
        • 48
        I have had that code on several machines and every time it turned out to be the index sensor, which is the sensor on the write unit.
        • bgkahuna
          • Aug 2008
          • 17
          Yikes!!! Still not the answer I wanted to hear.. The boss has already ordered the write unit.. Thanks guys,, I was just hoping for a quick and easy fix to make my customer happy thats all....
          • dogsbody
            • Jun 2007
            • 289
            Had that code and had to fix it quickly about 12 months ago. A little digging and the index sensor is the same going all the way back to the 7020. It was an early version of the part but it worked great and has kept working ever since.
            Of course if the sensor is not at fault this wont help but you never know.
            Cheers.
            The force will be with you always.
            • bgkahuna
              • Aug 2008
              • 17
              Wow ok great, Thanks alot Dog.. That is exactly the kind of news I need to hear.. Customer will be so very happy if it works THANK YOU OH SO VERY MUCH!!!!!
