b250/350 rolls paper
  • francois
    service manager
    • 32
    hi all
    i have a problem with the b250 and b350, the m/c rolls the paper when it exit the m/c. this problem start after we replaced the fuser rollers. we replace the thermester as well and it does the same thing. we use the di2510,3510 upper fuser rollers.
  • kingarthur
    • 1369
    are you using the original fuser or a recon. we have had this problem when removing a finisher. when you fit a finisher you have to remove the 3 grey "rollers", if you remove the finisher the paper curls on exit. check to see if they are on the fuser.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      kingarthur hit the nail on the head. You are most likely missing those gray rollers. I fought that battle once.
      • francois
        service manager
        • 32
        Jes i am using a original roller, and the m/c dont have a sorter.
        • francois
          service manager
          • 32
          yes i am using the original roller an it dont have a sorter connected.
          that gry rollers were the best one to use
          • minimerlin
            • 851
            Did the machine roll the copies before you changed the teflon roller in the fuser?
            The grey rollers that previous posts talk about are on the exit roller shaft on the machine and are not part of the fuser! Did your machine ever have a finisher fitted in the past?
            Please do not PM me without asking first.
            • RRodgers
              • Jun 2009
              • 1947
              I'd be willing to bet that the thermistor is not making proper contact with the heat roller causing the fuser to run a little hotter than it should. This would cause the paper to curl pretty bad.
              Also, flip the paper over in the cassette.
