C253-konica minolta logo
  • yourcopyneeds
    LOGO FROZE- Can not do a trouble reset either,after doing a trouble reset, will not say ok, just locked up
    Reset all counters and nvram
    what else you got??
  • copytechman
    • Nov 2008
    • 954
    Does the engine fire up (make the startup sounds) if so and you've done nvram already then ya may be looking at an MFP board.. had it happen.
    Regards!
    A.
    • yourcopyneeds
      i didnt replace the nvram, just reseated it
      • copytechman
        • Nov 2008
        • 954
        Do you have another "known" good nvram/mfp board to try?
        Regards!
        A.
        • yourcopyneeds
          that is my next step, replacing the mfp, hoping that will fix it, ty
          • copytechman
            • Nov 2008
            • 954
            I'd swap nvram's first (quicker and easier to try) and see if it fires up... if it does then the nvram's to blame (reseating it rarely does much). Then Mfp board.
            Regards!
            A.
            • kmcopier
              PSP
              • 183
              there is special firmware for this problem
              • Toxic
                • 698
                Did firmware solve this problem or something else?
                • Having a ball
                  • 17
                  what else you got??
                  Use NVram recovery firmware if the electronic counter is way out you will need anothe NVRAM however using one from another machine may cause issues should obtain from KM
                  • 8050
                    • 88
                    what else you got??
                    Have you tried the NVRAM recovery procedure 1st? Also Konica Minolta recommends when replacing NVRAM to replace the MFP with it.
                    • nvram
                      • Jul 2009
                      • 40
                      hi this is usually caused by corrupt firmware, re flash the machine with IV which is version 21, i have recovered several "dead" boards this way.
                      • SEnder
                        • Jun 2008
                        • 36
                        Replace Power supply board!
                        • ni311
                          • May 2008
                          • 658
                          My bet is on NVRAM recovery fimrware, the procedure is easy: write the firmware on a CF card, insert the card in the machine, start the machine and follow the on screen instructions. It is working like a charm.
