7145
  • mrgene
    • 53
    hey guys little help here I dont do konicas usally (ricoh) can anybody tell me how or what a f35-1 is and can it be reset. I will return the favor anytime on a ricoh product thanks
  • copytechman
    • Nov 2008
    • 945
    From da book:
    F35-1 Low fixing temperature abnormality
    (L2 burnt out)
    When turning on electricity to the
    L2 (Fixing heater lamp/1) for
    more than the specified period of
    time while in idling.
    Special reset procedure, lots of posts/threads on how to reset these if/when need be! Search is your friend!
    Regards!
    A.
    • siraphop
      • 54
      F35-1 reset
      1. get in 25 mode turn on sw1 off sw2 turn on sw2 while press 2,5
      2. dip sw put 3 bit number put 1 bit data put 0
      defective fuser section need repair before resetting
      • Ray G.
        • Sep 2008
        • 22
        Reset on the error code is fine, but first I would advise removing the upper fuser roller and cleaning the T-mistors. That usually prevents a repeat of the code. Good Luck.
