Bizhub 451 P-14 Error
  • Toefur
    Service Director
    • May 2009
    • 28
    Ive tried just about everything...aside from replacing the print heads. Any suggestions before I get manufacturer support?
  • 8050
    • 88
    P-14 means there is a skew problem. My experience is that it mostly deals with the black IU. 1st pull out the black IU and reseat it. But before locking the black IU hold it in place with your hand then lock it. Sometimes it doesn't sit right. The other alternative is if it doesn't work try replacing the black IU.
    PS - as a precaution reseat all IU's
    Hope this helps!
    • Toefur
      Service Director
      • May 2009
      • 28
      Thanks 8050. I replaced the black I/U already and have reseated all I/U's as well. I looked on Minolta's SSD site for the P14. Nothing there except what you said...replace the I/U.
      • DCPS
        • Mar 2008
        • 116
        There is a special firmware from KM for this problem. PRCB is the only part that has to be flashed with this special firmware (GC1-22).
        • emujo
          • Jun 2009
          • 3009
          had this issue a few weeks ago, tried I/U replacement, no help, installed special f/w, no help. Test mode charts showed black leading in one direction, lagging in other direction. Wound up replacing the PH to resolve this. I am assuming the poster ment 451C. EMujo
          • Albonline
            • Sep 2008
            • 1151
            replace print head unit! have seen ph unit cause maney weird nonlogoical problems on this family of mfps.
            • Toefur
              Service Director
              • May 2009
              • 28
              alright...PH it is...just another lovely day being a KM tech...(sigh)
              • buster68
                • Nov 2008
                • 181
                Don't waste your money and time on replacing the ph units. Follow this procedure step by step and I guarantee you the P-14 will go away, I've done this on atleast 30 machines and have had success with each one.
                1. Do "Skew Adjustment Reset" then run "Initialize+Image Stabilization"
                2. Turn off copier.
                3. Apply firmware GC1-22 for the Printer control. MFP firmware must be at atleast R5.
                4 Do "Skew Adjustment Reset" then run "Initialize+Image Stabilization" again.
                5. Turn off and on the copier.
                6. Run Gradation for all three modes and then run Stabilizer again.
                This has been a fix for me 100% of the time with P-14 codes.
                For reference look at TAD # TAUS0703835EN08 in the KM Knowledgebase.
                • Having a ball
                  • 17
                  this issue could be firmware depending on the firmware you have at the moment also could be transfer belt check with KM before wasting money.
                  • habik
                    • 2013
                    Re: Bizhub 451 P-14 Error
                    Hi I am having constant issue with C650 (+650) right this moment and would appreciate if anyone can send me a link to the GC1-22 special firmware on the Konica site...
                    Many Thanks
                    I looked through 1.5 hrs now and could not find it.
                    Firmwares HERE
                    • medmouncef
                      • Feb 2013
                      • 10
                      Hi
                      Me too, I am interested in the first degree. Please provide us the link or send it to us.
                      Greetings
                      Many Thanks
                      • medmouncef
                        • Feb 2013
                        • 10
                        Many Thanks
                        Look here : http://onyxftp.mykonicaminolta.com/D...&productid=952
                        For my part, I search without result the service manual for KM c451. If ever, you have it or know where I can find it, I don't to thank you not enough.
                        Greetings
                        • habik
                          • 2013
                          My Fix was shifting C and M laser to value 300 manualy.
                          Then all the other adjustments stabiliser reset and full gradation adjust.
                          "Quite a mile away from initial settings but it worked for me."
                          Firmwares HERE
                          • medmouncef
                            • Feb 2013
                            • 10
                            2. Turn off copier.
                            Hello
                            I followed this procedure to the letter but it did not work.
                            Greetings
                            • medmouncef
                              • Feb 2013
                              • 10
                              Hello
                              Can you tell me where exactly did you introduce these values? I can not find.
                              Thank you very much
