bizhub 350 fuser
  • reddog
    bizhub 350 fuser
    About how long does the fuser last on this printer??
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    the life is supposed to be 450k, but depending on how much coverage is on the prints it will be significantly less. They will always fail where the thermistor or thermostat sits against the upper fuser roller, as the toner build up on it destroys the coating and you'll end up with black marks down the copies. Same issue on b250, 350, di 2510, 3510 etc..
    • reddog
      PerthKMTECH
      Thank You, I have not dealt with Konica Minolta equipment until a couple days ago.
      • minimerlin
        • 851
        You do not have to replace the whole unit , it is reasonably easy to replace the rollers. Also watch out for the red sponge fuser exit rollers, they go off and fall apart.
        Please do not PM me without asking first.
        • OBXtech
          \tek-ˈni-shən\
          • Sep 2009
          • 37
          Originally posted by minimerlin
          ...it is reasonably easy to replace the rollers...
          giggle, laugh, giggle
          "I have not failed. I've just found 10,000 ways that won't work."
          -Thomas Alva Edison
          • minimerlin
            • 851
            Yep I know what you are thinking but when you have done the job as many times as I have......then it just becomes second nature and takes about 45 mins! Sorry!
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              It is a hell of a lot easier than the old di251/351 fusers.
              • Hansoon
                • Sep 2007
                • 3378
                Hans
