biz hub pro c500
  • copierlady
    • 338
    biz hub pro c500
    hey guys i just did a 100k pm on this c500 (fuser rebuild, corona replacement,filters, waste tank) worked fine for me but.... next day customer called to say copier is asking for (K) toner and when they instll new bottle the message will not go away i checked myself for operator error but they were telling the truth. anybody know whats up?
  • RRodgers
    • Jun 2009
    • 1947
    Open the toner add door and check to see if the delievery system is working ok. Also, check to see that they are using the correct toner for the machine and it's not some "off brand"
    • copierlady
      • 338
      How do i do that
      How do i check the delivery system? Not sure what you mean sorry. I pulled the bottle out (it was really hard coming out) and looked in the toner hopper it had a small pile ( a table spoon or so) of toner at the bottom of it that did not seem right to me. Not sure but i believe the box of toner was oem. The service manual says something about "old style vs new style " useing different toners but it is not specfic about it
      • Albonline
        • Sep 2008
        • 1135
        this unit has 2 interlocks on the toner door. one ,the photosensor tells copier the door is closed the other the microswitch ,is a kill switch to the motors for toner addition. if the switch is not made the sub hopper will not fill, hence the add toner message. hope this helps.
        • copierlady
          • 338
          door switches
          Ok thanks. Are both switches activated by the same arm? They do have a problem with the plastic arm on the door looks like someone tried to glue it back on.
          • RRodgers
            • Jun 2009
            • 1947
            If it's really hard to come out it's the wrong toner. (I've seen this) it's probably missing one of the veins in the bottle.
            This is the spot you can point it out and (if it's wrong which I'm leaning that way) I'm done until you get the right toner. Course, they will tell you it worked before, doesn't matter, you are only required to get the machine running to spec, the toner is out of spec and all bets are off.
            GL
            • Albonline
              • Sep 2008
              • 1135
              yes the interlocks are located/actuated togather. try cheeting the set with somthing see if the bottles turn. if they do you may need to disassemble the cover and reform the actuator bar.
              • copierlady
                • 338
                thanks
                thanks guys. i can't get back to the machine until mon. am to check those things (customer closed) you have a save new years, and i'll let ya know what i find out. your right they are gonna swear i did something to cause this because "it worked before" oh well such are the pitfalls of this job!
                copierladydoor switches
                • Si@danwood
                  • Mar 2008
                  • 154
                  Try opening and firmly reclosing the toner delivery unit(The one that swings out to the right of the machine so you can get to the process section) I have had exactly what you describe on a few occasions and all it was that the toner delivery unit not quite located correctly...Si
                  • Stirton.M
                    All things Konica Minolta
                    • Oct 2009
                    • 1804
                    Yep...*nods*
                    ---Groucho Marx
                    • random
                      Yeah, there are two switchs on the door, one tells the UI the door is shut and the other tells the engine the door is shut, stupid idea. Easy to have a false positive.
                      • copierlady
                        • 338
                        THANK YA
                        Yep the nods get it. It was the little magled door arm. Woring fine now thanks guys!
