hey guys i just did a 100k pm on this c500 (fuser rebuild, corona replacement,filters, waste tank) worked fine for me but.... next day customer called to say copier is asking for (K) toner and when they instll new bottle the message will not go away i checked myself for operator error but they were telling the truth. anybody know whats up?
biz hub pro c500
Open the toner add door and check to see if the delievery system is working ok. Also, check to see that they are using the correct toner for the machine and it's not some "off brand"Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
How do i do that
How do i check the delivery system? Not sure what you mean sorry. I pulled the bottle out (it was really hard coming out) and looked in the toner hopper it had a small pile ( a table spoon or so) of toner at the bottom of it that did not seem right to me. Not sure but i believe the box of toner was oem. The service manual says something about "old style vs new style " useing different toners but it is not specfic about itComment
this unit has 2 interlocks on the toner door. one ,the photosensor tells copier the door is closed the other the microswitch ,is a kill switch to the motors for toner addition. if the switch is not made the sub hopper will not fill, hence the add toner message. hope this helps.Comment
door switches
Ok thanks. Are both switches activated by the same arm? They do have a problem with the plastic arm on the door looks like someone tried to glue it back on.Comment
This is the spot you can point it out and (if it's wrong which I'm leaning that way) I'm done until you get the right toner. Course, they will tell you it worked before, doesn't matter, you are only required to get the machine running to spec, the toner is out of spec and all bets are off.
GLColor is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
thanks
thanks guys. i can't get back to the machine until mon. am to check those things (customer closed) you have a save new years, and i'll let ya know what i find out. your right they are gonna swear i did something to cause this because "it worked before" oh well such are the pitfalls of this job!
copierladydoor switchesComment
Try opening and firmly reclosing the toner delivery unit(The one that swings out to the right of the machine so you can get to the process section) I have had exactly what you describe on a few occasions and all it was that the toner delivery unit not quite located correctly...SiComment
Yep...*nods*"Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
random
Yeah, there are two switchs on the door, one tells the UI the door is shut and the other tells the engine the door is shut, stupid idea. Easy to have a false positive.Comment
