C451 error code cfa03
  • siliconfiber
    • Jun 2025
    Anyone have any ideas on this one?
    When the printer boots it gets an error cfa03 and does not boot, it will not clear or allow any other type of action.
    Thanks in advance.
  • netcomval
    • 11
    firmware error, re-write it to get rid of this
    • siliconfiber
      On this, is the firmware re-write an easy process or covered in a manual and such. We do not have support and I have no tech manual. Thanks for any help anyone can provide.
      • EUTech
        • May 2009
        • 14
        You need a CF card and a Firmware Imaging Tool. Do a search on this forum, I'm sure you'll find results.
        • Albonline
          • Sep 2008
          • 1144
          the key question here i think is what was done to the unit to make it give this code? have you tryed trouble reset?
          • laserman06
            Conservative in Exile
            • Dec 2007
            • 323
            Could have been something as simple as a power surge/dirty power. Have seen many issues with KM boxes and power issues.
            The family that prays together, stays together!
            Smile God created you and He doesn't make mistakes!
            Relax, God IS in control!
            Be still and know that I am God
            Ps 46:10
            • alexfixes
              • 68
              I agree
              I agree
              • kon
                • 55
                hard drive
                its the hard drive disable in system 2 and it will boot the copier
                • Barrne
                  Re: C451 error code cfa03
                  I managed to clear this error, there was a pdf causing all the problems, once i managed to delete it all was working ok.
                  • freixi
                    • May 2009
                    • 53
                    hy all.
                    have same problem to bizhub c220 error c-FA03. the blue transfair lamp blinking, Upgrade the Firmware not resulted. Not acess to the bizhub c220
                    have ne idea?
                    thx
                    Best regards
                    Freixi
