when you close the doc feeder with or without paper on glass it beeps and message on display is no matching paper install 11 x 17 paper. The only way I can get it to display ready and use doc feeder is lift adf only an inch or two so the exp lamp dont come on, then it will allow doc feeder to work. It will be fine until next time you open ADF all the way and then close it.
I turned off original detection and did F7-1 in tech rep mode. Also adjusted right adf hinge to see if that would allow magnet in front to have better contact, did not help.
Any other ideas appreciated. Thanks
