Noise from c220 fixing unit
  • Gerg?
    • Jul 2008
    • 67
    Hi
    When installing c220 many of them makes a strange noise after the paper came out. Maybe the fixing unit when it is releasing.
    In case you know the solution let me know.
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    The problem is caused by the motor pressure of fusing unit, when it releases, the noise can be heard. There is a contermeasure provided by KM, you should install it.
    Field technician since 1994
    • ni311
      • May 2008
      • 658
      Can you share the solution with us?
      Konica Minolta Error Codes - Explanations and Solutions
      • copytechman
        • Nov 2008
        • 939
        I would like to know this too as I have searched the ssd for a solution (as described) and couldnt find one!
        Regards!
        A.
