Bizhub C-203, Controller issues...
  • Oystercopy
    • Oct 2009
    • 623
    #16
    Nope...
    No biometric device installed.. LUCKILY...
    • alexfixes
      • 68
      #17
      no biometric.good news
      I haven't seen any that works yet.
      • Oystercopy
        • Oct 2009
        • 623
        #18
        O.K. well I went out today and did the recommended NIC Reset procedure with firmware, the one that comes with the NVRAM reset package... not only did it not fix the problem, but now the machine won't let me even GET INTO the Utility/Counter setting to Re-Set the IP Address back into the machine. Waited over 15 minutes.. no dice. So, i reflashed the NIC reset one more time and that didn't work either. I was afraid to (and was recommended NOT TO) do the NVRAM reset procedure, but now I think I don't have a choice. Also, just to piss me off further, the stupid thing gave me a C-F023 error code to boot... Now I don't know WHAT to do... I'm probably going to try the NVRAM reset, but that was a last resort.
        • Stirton.M
          All things Konica Minolta
          • Oct 2009
          • 1804
          #19
          Ok, once again. REFLASH THE FIRMWARE!!!! ALL of it, with the latest firmware.
          Resetting NVRAM is the absolute last thing you ever want to do on a machine, when everything else possible to do has been done, which you have not done everything else possible. KM Japan is very adamant about this. All internal counters are reset, not to mention that doing so could also render the machine inoperable under certain circumstances. If you want to verify it is NVRAM, swap NVRAM with another machine (don't print or copy anything, just verify function access). If it is shown that the NVRAM is at fault, you need to send it back to KM Japan so they can clone the chip for you. But I doubt the problem is there.
          The error code is one that is related to the MFP board. If firmware flashing does not correct the behavior, your problem most likely is with this board, which contains the system EEPROM where firmware is stored. This board just so happens to contain amongst other things, the network port. See attach file 1 and 2.
          NVRAM related errors are limited to only C-D3##. See attach files 3-5
          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
          ---Groucho Marx
          Please do not PM me for questions related to Konica Minolta hardware.
          I will not answer requests or questions there.
          Please ask in the KM forum for the benefit of others to see the question and give their input.
          • Oystercopy
            • Oct 2009
            • 623
            #20
            Dude, relax...
            As I stated, resetting the NVRAM is a last resort, but KM offers that as an option, and their tech support, although not wanting me to do this FIRST, offers it as an option. According the bulletin, only certain things in the machine, which are normal Service Mode changes, get reset during an NVRAM flash. Certainly, KM wouldn't offer it if it destroyed the machine. I've reset NVRAM in other machines before without catastrophic results, but maybe there is something about this particular model that I don't know.
            I can try to reflash the firmware with the regular update files, but I'm not sure the customer wlll let me do this now. These people are ultra-stressed about downtime.
            Thanks for the reply though...
            • Stirton.M
              • Oct 2009
              • 1804
              #21
              I am relaxed. But I am also trying to help you resolve a problem and prevent you from creating more problems for you and your customer. Also, since they cannot print to it, what difference does that make?
              And according to this TSB, what I have described to you is the corrective action....
              Solution ID TAUS0702439EN* Solution Usage 7
              Description
              F023.
              Solution
              CAUSE: MFPB failed.
              SOLUTION:Perform a Data Clear. Reseat all the connections on PWB-MFPB. Replace MFPB if necessary and flash MFP with most current firmware. If the problem persists, swap NVRAM.
              IMPORTANT: All requests for NVRAMs must be approved by the SSD Hotline and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
              PARTS :
              bizhub C550 - PWB-MFPB (p/n A00J H020 07)
              bizhub C451 - PWB-MFPB (p/n A00J H020 07)
              bizhub C650 - PWB-MFPB (p/n A00J H021 00)
              bizhub C203/C253 - PWB-MFPB (p/n A02E H342 05)
              bizhub C353 - PWB-MFPB (p/n A02E H341 05)
              Solution ID
              TAUS0702927EN* Solution Usage 28
              Description
              Network menu button is missing from Admin Mode.
              Solution
              CAUSE: Corrupt NVRAM and/or failed PWB-MFP.
              SOLUTION: Perform the NVRAM Recovery Procedure (see attachment for instructions).
              If NVRAM Recovery Procedure is unsuccessful, replace the PWB-MFP and NVRAM. To receive a replacement NVRAM, please utilize the Online Technical Special Program order form located within MyKonicaMinolta.com:
              1. Login to MyKonicaMinolta.com.
              2. Select the Service tab.
              3. Select Warranty, Repair, Special Programs (menu at left side of screen).
              4. Click on Warranty Services Technical/FOC Programs (in center of screen).
              5. Select NVRAM/BRU Replacement Program.
              IMPORTANT : All requests for NVRAMs must be approved by the SSD Hotline and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
              PART NUMBERS (PWB-MFP)
              bizhub C250/C250P/C252/C252P (p/n 4038 0121 06)
              bizhub C203/C253 (p/n A02E H342 05)
              bizhub C300 (p/n 9J06-H003-01)
              bizhub C352/C352P (p/n 9J06-0101-02)
              bizhub C353/C353P (p/n A02E H341 05)
              bizhub C351/C450/C450P (p/n 4037013104)
              bizhub C451/C550 (p/n A00J H020 07)
              bizhub C650 (p/n A00J H021 00)
              Though the above describes to clear NVRAM, this method clears the machine's main counts. You cannot recover that information.
              Other TSBs also describes problems that can arise with Licensing depending on any options (like i-Options) installed in the machine, or conflicts that can happen. By a downed machine, I am referring only to the time it takes to get a replacement NVRAM from KM Japan or to deal with red tape regarding certain options in the machine that require a code to reset them. Not to mention the hassle that includes for you and the customer. The following TSBs describe this.
              TAUS0800843EN
              TAUS0801227EN
              Firmware flashing takes 10 minutes at the most. Replacing the MFP board perhaps 30 minutes and another 10 to flash the machine. Do this during their lunch hour if it is such a concern.
              ---Groucho Marx
              • alexfixes
                • 68
                #22
                I just want to say it's really not wort of falshing NVRAM and that may not even work. i have done that and that didn't solve the problem. The only time I had to do NVRAM refresh was when i was missing
                network botton in admin section, i flashed the machine and that din't help, i then did NVRAM refresh and that didn't work, SSD reccomended to repalce the PWB-MFP including the NVRAM together and that's costly because the machine is not under warranty so customer is getting another machine. Aslo is not recommended to just swap out the NVRAM usally when repalcing the NVRAM you have to repalce the PWB-MFP.
                good luck
                • alexfixes
                  • 68
                  #23
                  Description
                  F023.
                  Solution
                  CAUSE: MFPB failed.
                  PARTS :
                  Solution ID
                  Description
                  Solution
                  TAUS0800843EN
                  TAUS0801227EN
                  good luck
                  • Gibraltar's Ghost
                    • Oct 2009
                    • 15
                    #24
                    Originally posted by alexfixes
                    From what I have seen so far is that you do not know how to resolve problems with konicas. What I have witnessed in this forum is your constant meddling in the advice of others and confusing the end user with absolute rubbish.
                    I had a similar problem and following what stirton said was almost exactly what I did to fix my problem with network failur on a C353.
                    And is it really necessary to repeat your poorly written response several times?
                    • Albonline
                      • Sep 2008
                      • 1151
                      #25
                      yes! quite an excelent observation!
                      • alexfixes
                        • 68
                        #26
                        relax dude!
                        also what i have noticed on this forum that your "manages "don't know what's going on when trying to connect simple scan to ftp network. no one could fix my issue with ftp sacn and I solved it my self and i have happy customers now. to me good field technician is one that knows electrical,mechanical engineering, network engineering and knows how to setup network in any envirenments, whether macintosh or pc, thechs get confuse of servers and they don't want to touch anything on the server.what i have seen so far none of konica techs are able to do these tasks,relax dude, I don't know what you talking about. obuivesly you are not technical and you are far from an engineer. konica techs are trained to just follow manuals and has no experience of fixing machines , all they do is changing parts, i worked with them long time and i traineed thses techs myself, they guy working 20 years still can't connect simple network dude.....dude........
                        • alexfixes
                          • 68
                          #27
                          relax dude!
                          Description
                          F023.
                          Solution
                          CAUSE: MFPB failed.
                          PARTS :
                          Solution ID
                          Description
                          Solution
                          TAUS0800843EN
                          TAUS0801227EN
                          • alexfixes
                            • 68
                            #28
                            • buster68
                              • Nov 2008
                              • 181
                              #29
                              after you get the other issues taken care of (C-F023, NVRAM), I'm afraid you may still have a network printing issue. I would recommend putting a network switch(if the IT guy allows it) between the copier and the network, and set the NIC on the copier to Auto negotiate. I suspect that the copier is on a Gigabyte network and for some reason, KonicaMinolta MFP's don't jive well with that network speed. I've seen the same problem on several C203, C353 that are on Gigabyte networks.
                              • alexfixes
                                • 68
                                #30
                                Thank you for the information. we can not change anything on this netwrk because it is such huge network here. The mfp on this copier is slower than the network. Once everytime they do have issues with transmitting and scanning, jod doesn't complete the job, and i beleive the speed is the issue like you mentioned..... I have to see if placing netwrok performance monitor will help on this case. i will monitor real time performance for routers,swiches,controllers,snmp devices and controller. If you ahve any other recomendation please let me know.
                                thank you
