mode service passord failure with the KM C203
  • karim-tech
    • 47
    i just forgot my service mode password and i don't know how can i solve this problem
    thanx for help
  • Albonline
    • Sep 2008
    • 1153
    as far as i know you will need to replace the novram.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Is that the actual error?
      Are you trying to get into tech rep mode?
      There is no password set for this mode.
      There are passwords set for the administrator, and if you are using user authentication or if you are using an optional HDD encryption module.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • n3o
        • 38
        does it let's you use the copier functions or it's stuck with this error, happend to me one time, entered the correct code , and locked up the machine, after unplugin and plug-in it to the power source everything got normal again , hope that will work
        • karim-tech
          • 47
          ok this is what i need
          the 3 of my image unit are full this is my problem and i need to change the image unit stop to the no stop to do the i don't access to my service mode
          can u suppose an other solution to solve this problem
          thx
          • Stirton.M
            • Oct 2009
            • 1804
            same as EVERY KM
            stop-zero-zero-stop-zero-one
            ---Groucho Marx
