di 3510 lines on copy. help....
  • brent
    • Nov 2008
    • 1212
    just noticed this yesterday. copier is a trade in that I did not notice before. lines on copy. I have attatched pics. I swapped drum. no change. changed dv unit. no change. this machine has no print controller so I can't test print and go around the scanner unit. what else could I check? all the gears in the back seem to be ok. I am asking for help guy's.. thanks
    brent
  • brent
    • Nov 2008
    • 1212
    just to clarify. the lines are not in the feeding direction. this is a konica minolta test chart copied from the glass in the portrait position.
    thanks. also tried to find out if this machine has a test print section. so I can see if the problem is from the ir. or the printer section
    thanks
    brent
    • brent
      • Nov 2008
      • 1212
      don't think about it too hard gents. I was able to solve the problem. I swapped out the sync clutch and that transport section and that the paper goes through. so problem solved.
      thanks
      brent
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Your test print will be the f-12 function. It is a sheet with lines on it.
